hi all,
in the rename window (reproduce: F2 in fullscreen mode):
a pulldown-menu with the last renamed files would be help-/useful.
please add such a thing ;-) so the user can choose filenames from older renaming sessions.
origin:
http://newsgroup.xnview.com/viewtopic.php?p=19254#19254
rename: need a pulldownmenu with the last renamed filenames
Re: rename: need a pulldownmenu with the last renamed filena
A list for recent filenames could be used for fullscreen mode, but for browser mode you won't be able to use that recent files list, since renaming is done "in situ" and without dialog. The list of recent filenames in Fullscreen would be helpful, but it would only help there, so I think we should not provide such a list.loth wrote:hi all,
please add such a thingso the user can choose filenames from older renaming sessions.
origin:
i always rename my files in FS, because renaming files in browser mode is very crappy.helmut wrote:A list for recent filenames could be used for fullscreen mode, but for browser mode you won't be able to use that recent files list, since renaming is done "in situ" and without dialog. The list of recent filenames in Fullscreen would be helpful, but it would only help there, so I think we should not provide such a list.loth wrote:hi all,
origin:
i.e.
-renaming of very long filenames...
-renaming of file if the cursor/fokus is on the last rows will not show the whole filename, but crops it (display only)
-some other things i don't remember now .-)
but why do you think we don't need a little helper like the pulldown-menu?
only because it's not available in browser mode, but in FS mode?
my opinion is, the more help i can get, the more i can use :-)
loth
Does it work or is there a bug?loth wrote:...
i.e.
Another bug?loth wrote:-renaming of file if the cursor/fokus is on the last rows will not show the whole filename, but crops it (display only)
My opinion is that things should be as consistent and intuitive as possible. A help is only a good help if you can rely on it and it is always available. This is not the case.loth wrote:-some other things i don't remember now .-)
don't know, if there is already a bug open for that, but if you play around some time with renaming in browsermode, you find a lot more "buggy" things.helmut wrote:Does it work or is there a bug?loth wrote:...
i.e.
same as above.helmut wrote:Another bug?loth wrote:-renaming of file if the cursor/fokus is on the last rows will not show the whole filename, but crops it (display only)
loth
