Stars added with Fujifilm X100V not all shown
eranbeard
I've added one star ratings to multiple photos using my Fujifilm X100V, but when filtering in xnview with the 'poor' star filter (i.e. 1 star), I only see a handful of the starred images (less than 50% of them). Why would this be?
eranbeard
Re: Stars added with Fujifilm X100V not all shown
I should add - I tested with Photo Mechanic, which showed all the starred photos, so it's definitely not an issue with the camera or the memory card.
with XnView Classic?
eranbeard
With XnView MP. Should I be using another version? I'm on Mac OS
No, but you wasn't in the good forum. Please send me a sample file?eranbeard wrote: Mon May 25, 2020 1:12 am With XnView MP. Should I be using another version? I'm on Mac OS
eranbeard
I'm sorry about that.
Here's a sample file with a one star rating that wasn't recognised:
https://www.dropbox.com/s/fd0mwn71vz7wx ... 9.JPG?dl=0
The '1 star' is correctly imported, if you select the file and use 'Update catalog from files'?
