I had to move some directories to free up some disk space, and now the categories filter no longer meshes with the directory files. Is there a way to realign them. I moved the files from c:\photo files to d:\photo files. XnView still looks for the files in the original directory. I then used Settings->catalog->relocate, but that didn't solve the problem.
Any suggestions?
Reattaching Categories
Re: Reattaching Categories
Did you use "Base path" ?
How many photos do you have to correct ?
At the top of the "categories" panel, you can use "categorie' s filter , export" to create a xml file containing the paths of photos that are in the catalog.
By editing this (text) file, maybe you'll be able to find what is the problem .
Sometimes it's easy with search/replace in your text editor , to get a right xml file.
Then, with "categorie's filter / import", you can repair your catalog. But ratings and color labels are lost.
If your categories are saved as iptc or xmp keywords, no probleme, else you must be very careful.
Catalogage avec XnviewMP :
