Impossible to apply a filter only on a part of the image.
Hartford
When I select only a part of the image and try to apply to it a filter like detail, focus restoration or denoise, the filter is applied to all the surface of the image. It whas not the case with the previous versions of XnView.
Hartford
Hartford
Re: Impossible to apply a filter only on a part of the image.
Ou plutôt merci ! J'avais oublié qu'on était en France.
This problem is supposed to be fixed in XnView MP 0.96.3. Please check and confirm the bug fix here.
