0.96.4 verticals
elfroggio
0.96.4 verticals
Post by elfroggio »
I use Rawtherapee 5.8 (linux/manjaro/kde) to "develop" my images.
I have a bunch of images, some are in the landscape mode and a few in the portrait/vertical mode. When I opened one of the vertical/portrait in Rawtherapee 5.8, xnviewmp created a second copy horizontal/landscape
XnViewMP created 6 files with ".original":
elie-20200718-9297.raf
elie-20200718-9297.raf.original
elie-20200718-9299.raf
elie-20200718-9299.raf.original
elie-20200718-9300.raf
elie-20200718-9300.raf.original
elie-20200718-9301.raf
elie-20200718-9301.raf.original
elie-20200718-9302.raf
elie-20200718-9302.raf.original
elie-20200718-9303.raf
elie-20200718-9303.raf.original
The ones highlighted in blue. I didn't highlight them, this was done by XnViewMP 0.96.4. I use the xnview appimage.
How can I fix this?
Thanks
$ inxi -Fxxxz
System:    Host: ethelbert Kernel: 5.4.52-1-MANJARO x86_64 bits: 64 compiler: gcc v: 10.1.0
           Desktop: KDE Plasma 5.19.3 tk: Qt 5.15.0 wm: kwin_x11 dm: SDDM
           Distro: Manjaro Linux
Machine:   Type: Desktop Mobo: MSI model: 970A-G46 (MS-7693) v: 2.0 serial: <filter>
           BIOS: American Megatrends v: 2.8 date: 01/08/2016
CPU:       Topology: 8-Core model: AMD FX-8350 bits: 64 type: MCP arch: Bulldozer
           L2 cache: 2048 KiB
           flags: avx lm nx pae sse sse2 sse3 sse4_1 sse4_2 sse4a ssse3 svm bogomips: 64024
           Speed: 3242 MHz min/max: 1400/4000 MHz boost: enabled Core speeds (MHz): 1: 3242
           2: 1987 3: 2953 4: 3358 5: 3570 6: 3920 7: 2183 8: 1903
Graphics:  Device-1: AMD Ellesmere [Radeon RX 470/480/570/570X/580/580X/590]
           vendor: Micro-Star MSI driver: amdgpu v: kernel bus ID: 01:00.0
           chip ID: 1002:67df
           Display: x11 server: X.Org 1.20.8 driver: amdgpu unloaded: modesetting
           alternate: ati,fbdev,vesa compositor: kwin_x11 resolution: 1920x1080~60Hz
           OpenGL:
           renderer: Radeon RX 570 Series (POLARIS10 DRM 3.35.0 5.4.52-1-MANJARO LLVM 10.0.0)
           v: 4.6 Mesa 20.1.3 direct render: Yes
Audio:     Device-1: AMD SBx00 Azalia vendor: Micro-Star MSI driver: snd_hda_intel v: kernel
           bus ID: 00:14.2 chip ID: 1002:4383
           Device-2: AMD Ellesmere HDMI Audio [Radeon RX 470/480 / 570/580/590]
           vendor: Micro-Star MSI driver: snd_hda_intel v: kernel bus ID: 01:00.1
           chip ID: 1002:aaf0
           Sound Server: ALSA v: k5.4.52-1-MANJARO
Network:   Device-1: Realtek RTL8111/8168/8411 PCI Express Gigabit Ethernet
           vendor: Micro-Star MSI driver: r8169 v: kernel port: d000 bus ID: 04:00.0
           chip ID: 10ec:8168
           IF: enp4s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
Drives:    Local Storage: total: 5.46 TiB used: 2.10 TiB (38.4%)
           ID-1: /dev/sda vendor: Western Digital model: WD30EFRX-68EUZN0 size: 2.73 TiB
           speed: 6.0 Gb/s rotation: 5400 rpm serial: <filter> rev: 0A82 scheme: GPT
           ID-2: /dev/sdb vendor: Western Digital model: WD30EFRX-68EUZN0 size: 2.73 TiB
Partition: ID-1: / size: 491.15 GiB used: 30.79 GiB (6.3%) fs: ext4 dev: /dev/sda2
           ID-2: /boot size: 999.7 MiB used: 98.5 MiB (9.9%) fs: vfat dev: /dev/sda1
           ID-3: /home size: 2.19 TiB used: 535.40 GiB (23.9%) fs: ext4 dev: /dev/sda3
           ID-4: swap-1 size: 13.67 GiB used: 0 KiB (0.0%) fs: swap dev: /dev/sda4
Sensors:   System Temperatures: cpu: 28.1 C mobo: N/A gpu: amdgpu temp: 40 C
           Fan Speeds (RPM): N/A gpu: amdgpu fan: 1002
Info:      Processes: 229 Uptime: 45m Memory: 11.65 GiB used: 6.05 GiB (51.9%) Init: systemd
           v: 245 Compilers: gcc: 10.1.0 Shell: bash v: 5.0.18 running in: konsole
           inxi: 3.0.37
Re: 0.96.4 verticals
you have use rotate in XnView MP right?
elfroggio
Post by elfroggio »
xnview wrote: Tue Jul 21, 2020 11:49 am you have use rotate in XnView MP right?
No!
XnviewMP was open (on my left monitor). I opened Rawtherapee (on my right monitor) and selected one (only one) of these images in Rawtherapee 5.8 to edit. As soon as RT started the edit, XnviewMp created the second set.
I didn't use XnViewMP to open RT.
Thanks
Syv
if you don't open XnView MP no file created?
elfroggio
Post by elfroggio »
xnview wrote: Wed Jul 22, 2020 3:43 pm if you don't open XnView MP no file created?
No, never.
That's why instead of going through the general support board/group, I came to the bug board/group.
Thanks
the .original files are not created by XnViewMP if you don't use rotate or metadata edit, are you sure that RawTherapee dont create these files
elfroggio
Post by elfroggio »
xnview wrote: Thu Jul 23, 2020 6:17 am the .original files are not created by XnViewMP if you don't use rotate or metadata edit, are you sure that RawTherapee dont create these files
Yes, I'm sure that it wasn't Rawtherapee. I have been using it for almost 2 years and it never created ".original" files.
BUT, I did enter/change some of the IPTC. Are you saysing that XNViewMP changed the raw file? Isn't it supposed to write these to the XMP sidecar?
I never want to modify the actual raw file.
Thanks
you have used 'Edit IPTC' on RAW?
elfroggio
Post by elfroggio »
xnview wrote: Fri Jul 24, 2020 6:43 am you have used 'Edit IPTC' on RAW?
I don't know :shock:
I did set some IPTC, but I was expecting to add it to the sidecar, never the raw.
Tools > metadata > edit iptc/xmp
How to just save to the sidecar? I don't want to modify the raws ever.
I have a whole bunch of tags to do....
Thanks
currently there is a little issue, IPTC dialog always modify the file not the sidecar
elfroggio
Post by elfroggio »
xnview wrote: Mon Jul 27, 2020 8:41 am currently there is a little issue, IPTC dialog always modify the file not the sidecar
Thanks.
Has a bug been filled? To get it fixed in a near future/version?
Thank you
elfroggio wrote: Tue Jul 28, 2020 2:46 pm Has a bug been filled? To get it fixed in a near future/version?
yes
elfroggio
Post by elfroggio »
xnview wrote: Wed Jul 29, 2020 7:19 am
yes
Thank you
