JPEG-LS
schobi
JPEG-LS
Post by schobi »
In the list of formats I found JPEG-LS ... I downloaded the normal version of 1.68.1 but there is no jpeg-ls support ...
what am I doing wrong?
thanks!
bye,
Michael
Post by Guest »
look for "xjpegls.dll" under "plugins" folder .. if not available download plugins.zip.. from xnview site..
MAAD
Easy way to find out about Plug-Ins
Maad's hint is correct, but there is an easier way to find out about the installed and recognized Plug-Ins:
Start XnView and select the menu "Info->Plug-Ins information". There, all the Plug-Ins installed (properly) are listed.
schobi
thanks..!
Post by schobi »
I downloaded the plugins and installed them - works fine! thanks!
