Problems with the category search
SteAl1988
Post by SteAl1988 »
Hi boys and girls, I'm struggling a little with the category search. That's one of the reasons why I have checked the forum for a suitable thread, but found nothing.
Here's the problem: I search for pictures with assigned categories and either all pictures with categories are found or none at all :?
With "Categories is..." it finds nothing and with "Categories contains..." it finds all pictures with categories. Although only the categories of one picture are selected.
Is there something I missed? I hope you can help me. Thank you very much for your answer :)
Best regards
Steffen :)
Re: Problems with the category search
could you post a search dialog screenshot?
SteAl1988
Post by SteAl1988 »
Thanks for your answer. I tried it again and it worked. Maybe it was just a mistake in my thinking or my workflow I had yesterday. But I still have two questions:
  • How can I quickly assign several categories to a picture without having to right-click each time to open the menu.
  • Are the categories then saved in the image file? Or how do I make sure that I don't have to do it again if I change the computer or the hard disk?
Thanks in advance for your answer :-)
Rick
Post by Rick »
Add categories to the left hand pane (the bottom on some layouts)
I can have (say) 20 photos, 5 of which are railroads. If categories are open and I select those 5, one click adds them to that category
Rick
Post by michel038 »
Go to Settings, Metadata and enable export catégories to xmp or iptc (only jpg photos ?).
For photos already categorized, you'll have to unmark / mark catégories to write them in photos.
SteAl1988
Post by SteAl1988 »
Rick wrote: Tue Aug 18, 2020 2:47 am Add categories to the left hand pane (the bottom on some layouts)
Thank you very much Rick! :D
michel038 wrote: Tue Aug 18, 2020 7:31 am
Also thank you very much Michel! :D
But what do you mean with "only jpg photos ?"? That you don't know if it only works on jpg photos?
Post by michel038 »
Some file types like jpg support xmp and iptc embedded metadata, Canon, Nikon,... raw files support only external metadata (xmp side-car files). For other file types, you will have to verify if it's possible...
SteAl1988
Post by SteAl1988 »
Okay, thank you! :)
SteAl1988
Post by SteAl1988 »
Thanks again for your answers! But now I have a new problem. I set the categories and assigned them to a picture. Unfortunately, not everything remains as it is :? It started when I made top categories to capture the categories there.
After that, subcategories were gone, moved or renamed. Then I changed everything again, but it happens over and over again. And currently it is the same :?
What can be the reason for this?
Thanks in advance for your answers :)
SteAl1988 wrote: Thu Aug 20, 2020 1:42 pm Thanks again for your answers! But now I have a new problem. I set the categories and assigned them to a picture. Unfortunately, not everything remains as it is :? It started when I made top categories to capture the categories there.
you can't add subcategories??
SteAl1988
Post by SteAl1988 »
I can, but the Categories change their name.
SteAl1988 wrote: Tue Sep 01, 2020 4:20 am I can, but the Categories change their name.
sorry but i don't understand the problem
