0.97.1: Crashes at startup, with simple override updates.
Mapaler
Post by Mapaler »
XnView: MP 0.97.1 - 64-bit
OS: Windows 10 - 64-bit
Effect: XnViewMP crashes at startup
I like green software, so I've been using the zip version and store settings in the ini way.
This time, after overwriting the new version of the file directly, there was a crash.
▼In addition, garbled code appears in the text box of the crash window(zh-CN environment).
  1. Unzip, then use my override update version.
    https://1drv.ms/u/s!AmFzz3_4XoK_g7JmS91 ... g?e=e2WeDg
    This overlays several years of updates. So I can't say for sure how it came about.
  2. Run XnViewMP.
  3. Actual behaviour (bug): XnView crashes :bug:
  4. Unzips a brand new XnViewMP.
  5. Expected behaviour: No crash, XnViewMP is run. But lost all my settings.
Re: 0.97.1: Crashes at startup, with simple override updates.
Please remove plugins\bearer\qnativewifibearer.dll (from an old version)
Mapaler
Post by Mapaler »
xnview wrote: Mon Oct 26, 2020 11:26 am Please remove plugins\bearer\qnativewifibearer.dll (from an old version)
It's working, thanks!
