Windows 2000 Double-click will NOT open image view in XnView
[email protected]
Post by [email protected] »
I like the user interface of XnView better than IrfanView.
However, I tried EVERYTHING I could possibly find and I could not get XnView to open / view images in windows 2000.
I set file types to OPEN via XnView in the Win 2000 Tools / Folder Options. Nothing happened.
No preferences I could find in the program either.
Not the viewer I want to use if Double-Click to view won't work. Wish it did, I like the work done so far.
Bill Mitchell
Re: Windows 2000 Double-click will NOT open image view in Xn
[email protected] wrote:I like the user interface of XnView better than IrfanView.
There was a thread about this problem, but can't find it :-(
Which key value do you have for HKCR/XnView.*? (if you know registry)
helmut wrote:There is a FAQ "How to associate image files with XnView".
No helmut, in 1.80 first release there was a bug in setup, and a bad key was created.
O.k. I guess it this one: "Can't view JPG file by using XnView".
