copy name to clipboard
rnmerchant
Post by rnmerchant »
Good evening!
I'm looking for an easy way to copy a filename to the clipboard. The command avaialble is /edit/copy to clipboard/selected filename and path.
Is there a shortcut key for that command? Can one make one? I don't see how from the menus...
On my tools/settings/shortcut keys the entire menu is "cmd / ...". It seems to me the key commonly called 'cmd' is a Mac key - is the list of shortcuts equivalent on the PC (? the Windows key).
2 questions, I suppose.
Thanks Richard
Re: copy name to clipboard
you can it in settings>shortcuts
