Good day,
May I ask to update the EXIFTOOL to version 12.09 to be able to get more EXIF data for Olympus OM-D E-M1 MK3 images (Tags: StackedImages and DriveMode).
Thanks in advanced.
Bernard
Please update to new version 12.09 of EXIFTOOL
travelphoto
MacBook Pro, MacOS Mojave 10.14.6
XnView MP MacOSX
Version 0.97.1 64bits (Oct 14 2020)
XnView MP MacOSX
Re: Please update to new version 12.09 of EXIFTOOL
If your OS is Windows, you can download the new version of exiftool ...
Go to the installation directory xnviewmp, and go to the "AddOn" folder
- rename existing exiftool.exe > exiftool.old
- unzip the downloaded exiftool12.09.zip and rename exiftool(-k).exe > exiftool.exe in the same place as the original (...\XnViewMp\AddOn\ )
Catalogage avec XnviewMP :
travelphoto
dear michel038, thanks for your information. Unfortunately I've forgotten to mention my OS is Mac OS Mojave. Do you have a solution for Mac as well?
Thanks and best regards,
Bernard
Bernard
XnView MP MacOSX
XnView MP MacOSX
brianlamb
You can "manually" update the exiftool in the XnViewMP app bundle on macOS.
Note: I am not sure if there is a better more "official" way to do this, or if there are any unintended side effects.
My guess is since this is just a perl library tool it's actually a pretty simple thing to do this drop in replacement.
Here is the process:
Download the exiftool you want to use as a drop in replacement (the latest is now 12.10)
it installs these into default locations:
(this is the executable)
(these are two supporting folders)
Then, open the app package for XnViewMP.app
Copy the exiftool file/folders from the above locations and paste them inside this application bundle.
You don't even need to restart the XNViewMP app although you might as well just in case.
Again, I don't know if this is supported behaviour and the XNViewMP app may soon have the updated exiftool embedded anyway soon.
Perform at your own risk!
~Brian
/usr/local/bin/exiftool(these are two supporting folders)
/usr/local/bin/lib/Image/ Code: Select all
/usr/local/bin/lib/File/ Then, open the app package for XnViewMP.app
~Brian
travelphoto
Dear Brian,
Sorry for the late reply. Thanks for your suggestion. It is working now! Nevertheless will install the newest XnView version as soon as available
Best regards,
Bernd
Best regards,
Bernd
XnView MP MacOSX
XnView MP MacOSX
