AVIF support
damian101
AVIF support
Post by damian101 »
Browsers support AVIF, XnView MP should too.
Re: AVIF support
AVIF is supported already
Orios
Re: AVIF support
Post by Orios »
Hello Pierre, how can I enable AVIF support for XnViewMP in Linux?
XnViewMP is not able to recognize this format, and AVIF (as well as HEIF) are not even listed by the XnViewMP app among supported formats either for reading or writing even in Linux environments where I can enable AVIF support for other image browsers like Gvenview. It applies to XnViewMP distributed in both Debian and AppImage packages (downloaded from XnView.com websites).
It's pity because XnView is a great piece of software that I find useful especially for batch conversions to latest space-efficient image formats like AVIF and HEIF. Thank you for your answer and for your work on XnView!
Tom
dma_k
Re: AVIF support for Linux
Post by dma_k »
Same question here: AVIF support in .deb distribution for x64 Linux (v1.4.5) is missing.
Torsten
Re: AVIF support
Post by Torsten »
I can confirm that AVIF still seems unsupported in XnView MP 1.8.2 for Linux 64-bit, namely in DEB, TGZ and AppImage. The AVIF format is not shown in the save dialogue. I use Debian 12 (Bookworm). However, it works in the Windows version.
Re: AVIF support
do you have installed libheif?
Torsten
Re: AVIF support
Post by Torsten »
Uhm, no, I hadn’t … But after installing it, everything works fine. Thanks for your support!
