XnViewMP - Favourite folders dropdown arrows missing after upgrade.
robz
Post by robz »
I've just upgraded to XnViewMP 0.98.0 on my iMac (OSX 10.13 High Sierra) and I immediately noticed the missing dropdown arrows beside each folder in the favorite bar, which I use a lot while browsing the catalog. Same thing happened on another Mac I have, running OSX 0.15 Catalina. Could someone help me restore these dropdown icons?
Thanks a lot for your help,
best regards,
Roberto
septimv
Re: XnViewMP - Favourite folders dropdown arrows missing after upgrade.
Post by septimv »
Hi.
I second this. Favorite folders are missing the dropdown arrows since 0.98, Win10 here.
It's been very useful function. I hope it to be re-added soon.
Thanks.
Please check this
septimv
Post by septimv »
Thanks. Now I got it back.
It's very convenient when sorting files into multiple directories inside. I don't know why it got turned off by default.
But again, Thanks.
robz
Post by robz »
Thanks for your answer, I see!
I'm relatively new to XnView, I discovered it only a few months ago and I'm not an advanced user... could you help me with the procedure of editing the INI file please? Where do I start from?
Thanks a lot for your time,
Roberto
robz wrote: Tue Jan 19, 2021 5:17 pm I'm relatively new to XnView, I discovered it only a few months ago and I'm not an advanced user... could you help me with the procedure of editing the INI file please? Where do I start from?
You can find the location of the ini file from Tools > Settings > Integration -- Paths and then open the folder containing the file.
Open the ini file in a text editor (if necessary, temporarily change the extension to .txt so that it can be opened).
Then search (easier using Ctrl-F) for the line to be edited, edit it as above, and resave the file (and if necessary change the extension back to .txt).
Then restart XnView MP...
robz
Post by robz »
Thanks a lot,
I've located the .ini file, changed the extension to .txt and opened with the text editor, but the I can't find the lines
CODE: SELECT ALL
FavShowFiles=
Can I insert
CODE: SELECT ALL
FavShowFiles=True
somewhere anyway in order to have the dropdowns appear?
Thank you for your help.
robz wrote: Sat Feb 06, 2021 10:26 am Can I insert
CODE: SELECT ALL
FavShowFiles=True
you need to add it in [Browser] section
