XnView MP Windows
Version 0.98.1 64bits (Jan 20 2021)
Libformat version 7.65
How to not rotate image after crop?
How to not reset zoomed scale when list images?
How to crop image in full view?
How to use same crop format (size) to not need each time to adjust it?
Need help
Re: Need help
could you explain me more your problem?
Rawas
Re: Need help
1. when i crop image it auto rotating 180 degrees, i dont need rotating (probably because after set crop size i use mouse roll to move next image, i get warning to save image, i saving, and when scroll back, image became autorotating and saved in that state, if not use mouse scroll, and press save button before, image not autoroting)
2. When i go to next image, zoom scale from previous images is reseting, and i need again zoom to same scale (for example i want to see only center of each image scaled to 300x zoom)
3. in full screen view there are not option to crop image
4. All my images is same size and same scale (scanned books) i need quick crop 10.000 images, so very slow to fit to same crop size each image, i just want to click next, and insuring in good crop size and place, crop image and save.
Re: Need help
there is no auto rotate, perhaps your image has an orientation EXIF field. Could you post it?Rawas wrote: Mon Jan 25, 2021 4:41 pm 1. when i crop image it auto rotating 180 degrees, i dont need rotating (probably because after set crop size i use mouse roll to move next image, i get warning to save image, i saving, and when scroll back, image became autorotating and saved in that state, if not use mouse scroll, and press save button before, image not autoroting)
even if you use 'Lock zoom'?2. When i go to next image, zoom scale from previous images is reseting, and i need again zoom to same scale (for example i want to see only center of each image scaled to 300x zoom)
you need to be in edit mode (fullscreen or not)3. in full screen view there are not option to crop image
Why you don't use 'batch convert'?4. All my images is same size and same scale (scanned books) i need quick crop 10.000 images, so very slow to fit to same crop size each image, i just want to click next, and insuring in good crop size and place, crop image and save.
Rawas
Re: Need help
1. How to do that? file to large to post here
2. yes, lock zoom
3. yes, need crop tool in any mode
4. as not all images well adjusted and i need control each image crop, i need crop lock too, but move this lock over image
2. yes, lock zoom
Re: Need help
you can use wetransfert service
Settings>View>Reset auto image size is unchecked?2. yes, lock zoom
you have it in fullscreen from edit mode3. yes, need crop tool in any mode
Rawas
Re: Need help
1. https://www.sendspace.com/file/ayc9vc
2. ok.ty, but it not working, reset zoom anyway, no one of selected option from dropdown not make any changes to zoom, after go to next image it reseting always, same with checked and unchecked box
3. not, i dont have any https://www.sendspace.com/file/0jp1od
Re: Need help
When I crop IMG_0153.JPG in edit mode I have no rotation...
In fullscreen you can enable the crop tool using Shift+X.
But if you have a large book scanning project, you should possibly also look at a utility called ScanTailor, specifically designed for processing large numbers of book scans and highly recommended by people who have used it. It is available in several versions now developed from the original tool.
There is also a forum dedicated to book scanning DiyBookScanner which might be worth a look, although it is rather quiet now.
Rawas
Re: Need help
Ty, i wiil study ScanTailor
Attaching video https://www.sendspace.com/file/uk3861
After pressed save confirmation i scrolling back forward with mouse scroll
