Batch convert to relative subfolder
tlegras
Post by tlegras »
I might be a classical question but i couldn't find anything like that in the forum:
i have pictures classified in a big folder tree with several subfolder level. something like this:
  • 2004
    • January
      February
    2005
    • January
i would like to generate for each picture a thumbnail that is placed in a subfolder:
  • 2004
    • January
      • thumbnails
      February
      • thumbnails
    2005
    • January
      • thumbnails
so i tried thumbnail\%.jpg or .\thumbnail\%.jpg etc. for destination deirectory option, but all is always generated in the same folder. is there any way to tell xnview to use relative path for generating transformed file, not absolute path?
Thks for any help
Thierry.
<Moderator's note: The subject of this topic has been changed.>
Re: batch rename to relative subfolder
tlegras wrote:I might be a classical question but i couldn't find anything like that in the forum:
  • 2004
    • January
      February
    2005
    • January
  • 2004
    • January
      • thumbnails
      February
      • thumbnails
    2005
    • January
      • thumbnails
Thks for any help
Thierry.
Batch rename or batch convert???
tlegras
Post by tlegras »
Thks for you quick answer.
i did not tried batch rename, but as far as i could see batch convert will save the transformed to the same thumbnail folder. so i have to repeat manually the operation for each folder (January/February, etc.). what i could like is to do once a batch convert for the whole hierarchy, and the thumbnails are generated each time in a local subfolder.
Is it possible?
tlegras wrote:Thks for you quick answer.
Is it possible?
Right % is only used for original filename, you have no character for original folder...
With XnView 1.90 this is possible using the $ placeholders. Please see topic "relative paths in batch convert" for more details.
