ESC key behavior in XnView MP
KRG_JP
Post by KRG_JP »
I'm using XnView Classic and XnView MP in parallel.
In terms of functionality and performance, I would like to make a complete transition to MP, but the difference in ESC key behavior prevents that.
When multiple tabs are open, Classic closes the open tabs and returns to File view. However, MP closes the open tab and opens the next tab.
I don't understand if this difference is due to my misuse or just a spec.
Please give me some advice.
Thanks.
Re: ESC key behavior in XnView MP
you would like that ESC closes current tab and returns always on browser view?
KRG_JP
Post by KRG_JP »
xnview wrote: Mon Mar 29, 2021 3:07 pm you would like that ESC closes current tab and returns always on browser view?
Yes, I want it to always behave like that.
Please enable Settings>Interface>synchronize browser...
KRG_JP
Post by KRG_JP »
Thank you for your proper advice.
