I was trying to rename a file called 10 - Speed Test - 1237MBs (9.896Gbps).png.
When I selected the file and pressed F2 to rename it only highlighted the 10 - Speed Test - 1237MBs (9 section when it should really select it all.
Renaming files with a period in name [Solved]
stevehero
Re: Renaming files with a period in name
on Windows?
stevehero
Yes, latest build.
if i use F2, '10 - Speed Test - 1237MBs (9.896Gbps)' is highlighted
stevehero
For some strange reason when I was renaming that file last night it had this behaviour where it would only select a portion of the filename up until the first period.
I suppose you can close this issue.
