Edit IPTC - Load Template Question ???
BuckSkin
Post by BuckSkin »
In the Edit IPTC editor, in the Load Template "Choose Template File" dialogue, there is a check-box, "Merge datas" ; what does this do when checked ?
Thank you.
Re: Edit IPTC - Load Template Question ???
datas are merged between the template and the fields in dialog
BuckSkin
Post by BuckSkin »
xnview wrote: Tue May 25, 2021 6:04 am datas are merged between the template and the fields in dialog
Does that mean, if I have an image file that already has some IPTC data, instead of the template erasing that data, it will leave it in place and add the data from the template ?
BuckSkin wrote: Tue May 25, 2021 6:13 am
yes you can try
