Drag&Drop for Excel
fj_ac
Drag&Drop for Excel
I could Drag&Drop to Excel from XnView when Ver0.98.3.
but, I can't Drag&Drop to Excel from XnView when Ver0.98.4.
It is a useful !!
I want came back it.
It is a useful !!
Re: Drag&Drop for Excel
drag&drop from browser?
fj_ac
Software like Internet Explorer? -> Nobrowser?
Windows filer? -> No
XnView pane name? -> ?
Sorry, I don't know pane name.
[DD.jpg] Drag&Drop img file XnView to Excel.
[Res.jpg] result.
in your screenshot, it works?
fj_ac
It works.
Rolled back to 0.98.3.
Does not work with 0.98.4.
What's happened?
fj_ac
I think so too.
That's why I started this thread.
Maybe I'm the only one who can't do it?
Rather, maybe other people can do it with 0.98.4?
Am I crazy?
But what's happened when you drag&drop?
fj_ac
Is the correct behavior of 0.98.3 not being able to D&D to Excel?
Why is it possible?
ok, but what's happened with 0.98.4?
fj_ac
Nothing happens.
In 0.98.3, dragging now adds a border to the cell.
When I drop an image, it is inserted.
As soon as i drop it, the Excel window becomes active.
In 0.98.4, dragging does not put a border on the cell.
Nothing happens when I drop it.
The focus of the window does not move either.
The mouse cursor is just moving, but nothing happens.
Are you able to do D&D in 0.98.4?
I don't understand why Calc/Excel doesn't accept drag&drop, so i add a hidden setting
See issue
See issue
This problem is supposed to be fixed in XnView MP 0.99.0. Please check and confirm the bug fix here.
fj_ac
Sorry about that.
I had given up and continued to use 0.98.3, so I had not checked here.
I did check, but D&D was not possible.
I tried 0.99.0 and 0.99.1 and both were the same.
Microsoft Excel for Microsoft 365 MSO (16.0.14326.20384)
D&D was not able to do both, normal startup and safe mode.
If it is working fine for the development team, then there may be something wrong with my computer.
Thank you very much for your help.
I'll keep on using XnView!!
do you have changed General\dropLink in xnview.ini?
