If I open an image and save as it doesn't use the current directory of the image but it directs to the desktop.
Is there a way to save the image as to the current directory?
Normally with any program saving as will automatically have the directory of the original file as the default.
Saving the image as to the same directory [Solved]
stevehero
Re: Saving the image as to the same directory
settings>General>file operations - for 'save as'...
stevehero
Thanks. I don't know how I missed that option.
