Custom keyboard shortcut?
djfm
Post by djfm »
Is there any way I can create a keyboard shortcut for the action 'crop, then save' instead of having to push Shift+X and then Ctrl+S?
This (crop, then save) is the only thing I do with this software, it would be nice if I could make that even easier.
Thanks in advance!
Re: Custom keyboard shortcut?
currently there is no way to assign more than 1 command to shortcut
Rick
Post by Rick »
There are macro programs out there that will record your keystrokes and let you assign a key combo to execute. You can make some really intricate macros
Rick
Rick wrote: Sat Jun 19, 2021 4:09 pm There are macro programs out there that will record your keystrokes and let you assign a key combo to execute. You can make some really intricate macros
+1
There are some very powerful tools as you say, I only used one briefly a long time ago.
But can you recommend a very basic utility that might be of more immediate help to djfm, ideally just a macro recorder?
@djfm : Are you using Windows?
Here are some results from a quick search:
17 Best Free Macro Recorder tools to Perform Repetitive Tasks
13 Free Macro Recorder for Windows 10 to Automate Your Tasks
