B1: Batch Convert - Output dir. improvements
Dreamer
Post by Dreamer »
What about these improvements http://newsgroup.xnview.com/viewtopic.php?p=19490#19490 ?
At least easier way to use original path should be find for 1.82, I think. Many users don't know about it and ask how they can do it...
XnView 1.82 <x>
Re: B1: Batch Convert - Output dir. improvements
Dreamer wrote:What about these improvements http://newsgroup.xnview.com/viewtopic.php?p=19490#19490 ?
I've added $ for original folder name
Brr, it's getting worse with the place holders. :-| This is something for experienced users, but nothing for novice & normal users.
What we really need is a direct acces to original folder name. Various solutions have been discussed in the topic mentioned above.
marsh
Post by marsh »
Nice feature. Perhaps a new text file "command.txt" would be useful for placeholders and other advanced features.
Dreamer
Post by Dreamer »
Yes - and the best for normal and advanced users* and probably also easy to implement is this one:
...single button with dropdown menu and these items (with explanation) - same as Insert button in Batch Rename:
- Use org. path for images (it would empty the dir. path)
* - normal users could use drop down menu, advanced users just symbols
Note: Options/symbols above my be incorrect, more options could be added, in 1.82 just few of them could be added...
Batch convert dialog (2 lines) could look like this:
Directory [          ] [Insert >>] [...]
Format    [          ] [    Options    ]
Xyzzy
Post by Xyzzy »
Pierre, will there be any more improvements with regard to this thread?
Close?
X.
Xyzzy wrote:Pierre, will there be any more improvements with regard to this thread?
Close?
Not now
Xyzzy
Post by Xyzzy »
I understand 'Not now' refers to improvements, so Postponed.
X.
Dreamer
Post by Dreamer »
I think this is quite important, for novice (but also for advanced) users. We had many questions about this existing/hidden option.
At least some tooltip should be added, or it could be added to the "Tip of the day" maybe...
Moved back to "New/Open".
Dreamer
Post by Dreamer »
OK, postponed.
