b1: "Edit IPTC data" dialog: Scrolling tabs
In "Edit IPTC data" dialog (Edit > Metadata > Edit IPTC data) the tabs on top have scroll bars. The scrollbars do not look nice and makes controling the dialog more cumbersome.
Note:
When fixing this also other languages (e.g., German) with longer labels should be taken into account.
Note:
Re: b1: "Edit IPTC data" dialog: Scrolling tabs
Do you means that i must enlarge this dialog??helmut wrote:In "Edit IPTC data" dialog (Edit > Metadata > Edit IPTC data) the tabs on top have scroll bars. The scrollbars do not look nice and makes controling the dialog more cumbersome.
Note:
The "Previous" and "Next" buttons need too much space and should be changed (see other topic). Also, the preview can be smaller. And last not least the dialog could be a bit wider if needed.xnview wrote:Do you means that i must enlarge this dialog??helmut wrote:In "Edit IPTC data" dialog (Edit > Metadata > Edit IPTC data) the tabs on top have scroll bars. The scrollbars do not look nice and makes controling the dialog more cumbersome.
Note:
Fixed in b2: tab headers fit, no need to scroll.
BTW, I'd bet in many translated versions they will be scrolled.
Fe. translated strings for Polish, if not abbreviated, are:
Opis, Słowa kluczowe, Kategorie, Prawa, Status, Data/czas, Pochodzenie.
Maybe multirow header tabs instead of scrolled tab headers are a solution?
X.
X.
I would like to try it first.xnview wrote:I can make multirow, but everyone agree with that?Xyzzy wrote:Pierre, can multirow tabs make it into 1.82 or Postponed?
