The preview pane (yellow circle) show up when zoom in.
I would like to disable it.
Thanks.
How to disable preview pane when zoom in the photo? [Solved]
pk169169
Re: How to disable preview pane when zoom in the photo?
Tools > Settings.. View -- View tab -- Show Pan tool, I think.
Only shown when an image is zoomed in, I think.
One of a number of fairly recently added options which, personally, I would rather were not default settings, you might also take a look at some of the other view options... But that does at least draw attention to their availability!
pk169169
The problem is solvedcday wrote: Fri Sep 03, 2021 4:32 pmTools > Settings.. View -- View tab -- Show Pan tool, I think.
One of a number of fairly recently added options which, personally, I would rather were not default settings, you might also take a look at some of the other view options... But that does at least draw attention to their availability!![]()
Thank you very much!
