Tag schreiben
Tommes
Tag schreiben
Post by Tommes »
Hallo,
wenn ich mehrere Fotos gleichzeitig tagge, muss ich immer warten, bis die Tags in die Datei geschrieben sind.
Gibt es die Möglichkeit alle Tags zu setzen und die Tags dann erst ins Bild zu schreiben.
Lieber am Ende einmal lange Rechenzeit als mehrere Kurze.
Danke für eure Hilfe,
Tommes
Re: Tag schreiben
how many files do you tag? which format?
Tommes
Re: Tag schreiben
Post by Tommes »
I tag ten jpg images with the same tag.
In total there are probably 200 images.
Re: Tag schreiben
and the problem is the delay of writing?
Tommes
Re: Tag schreiben
Post by Tommes »
yes, I have to wait while writing about 20-30 seconds.....
Re: Tag schreiben
not normal, could you post a screenshot of settings>Metadata? and you tag only jpeg files?
Tommes
Re: Tag schreiben
Post by Tommes »
Here my settings.
What is also striking: XNView MP takes an extremely long time to start: about 60 seconds.
Re: Tag schreiben
How do you tag the files? Could you send me a sample jpeg file used?
Tommes
Re: Tag schreiben
Post by Tommes »
I select the photos and check the corresponding box in the category bar.
Attached is an example photo.
Re: Tag schreiben
i've tried with 20 copies of this file, and no delay. You select files, check a category, click on a file and you have the delay?
Tommes
Re: Tag schreiben
Post by Tommes »
I think I have found the problem.
My photos are stored on my NAS and I access them via Wi-Fi.
That is what is causing the delay.
When I copy the files locally I have no delay either.
Re: Tag schreiben
Ok, when tag are written, the full file need to be loaded and rewritten
