Select "Folders", go to File Listing, select to do "Folder Name" only, Text, nothing else checked, preview and save, both show 3 folders of the same folder in the list of every folder in the list. So 3, 3, 3, 3... (though one of them below listed just twice).
Folder name
CyberLink AudioDirector Ultra 12.0.2219.0
CyberLink ColorDirector Ultra 10.0.2207.0
CyberLink PerfectCam Premium 2.3.4703.0
CyberLink PhotoDirector Ultra 13.0.2222.0
CyberLink PowerDirector Ultimate 20.0.2204.0
I.e. Haven't tested other options, just needed this one thing and it's not working.
p.s. Can you also add a checkbox in which we can choose NOT to have the above words "Folder Name" or otherwise listed in the output?
Thanks
XnView MP "File Listing" creates duplicates in the List.... BUG
leeuniverse
Re: XnView MP "File Listing" creates duplicates in the List.... BUG
you have selected a folder, so files of subfolder are listed
leeuniverse
Not correct... Those are the names of the Top-level FOLDERS I selected. In other words, there should be only ONE file/folder with that name.
I also did not select the "subfolders" option. As well, there are no subfolders or files, let alone subfolders or files with those names below the top-level folder.
There are ONLY "files", and those files have completely different names.
So, this IS a bug...
Also, from what I understand on how the function works, unless I selected "files" as one of the filters/conditions, it should not be listing any "files"? I have only selected "folder" as a condition as the below image shows.
Thanks for responding...
the "File listing" lists the files, i think that you have something like:
CyberLink AudioDirector Ultra 12.0.2219.0\file1
CyberLink AudioDirector Ultra 12.0.2219.0\file2
CyberLink AudioDirector Ultra 12.0.2219.0\file3
CyberLink ColorDirector Ultra 10.0.2207.0\file1
CyberLink ColorDirector Ultra 10.0.2207.0\file2
CyberLink ColorDirector Ultra 10.0.2207.0\file3
leeuniverse
So, you're saying that simply because I have "3 files" for example "within" the folder, even if they are completely different names, THAT is why XnView is duplicating 3 folder names?xnview wrote: Tue Nov 09, 2021 8:56 am the "File listing" lists the files, i think that you have something like:
So, then yes, that would seem to be what's occuring...
However, I don't know why you would have the program functioning this way, this function would seem to need to change?
I mean, I'm wanting to list the "Folder Names" in my directory, per my peramators/filters set, not create the same folder names according to how many files are within the said directory, that makes no sense.
Hope you can correct this functioning... Thanks.
it list files not folder
leeuniverse
Uh, but I set the filter to list "Folders", not files... If I wanted to list files I would have selected the "File" Filter.
I also have un-checked "List Subfolders", thus if I wanted subfiles to be listed, I would have that checked.
Again, this doesn't make sense. So, this needs to be changed.
Gwenael Q.
What you call "filter" is not a filter but a variable field. Files are always listed within this command, but user can choose what will be displayed for each file by the means of the variable fields. So there is no bug here.
I hope it helps.
That said, perhaps Pierre could add an option "Skip redundant line if any" ?
I hope it helps.
