Draw tool - Grid display option
While creating some test images, a 'display grid' option would have been useful to enable (in this case) text numbers to be positioned in the same position on the screen when the images are viewed successively.
Re: Draw tool - Grid display option
the same grid as in viewer?
xnview wrote: Sun Nov 07, 2021 8:24 am the same grid as in viewer?
Any grid, the viewer grid might be a good start if that would be easy for you...
ruler or grid?
xnview wrote: Wed Nov 10, 2021 12:48 pmruler or grid?
I'm not sure exactly what you mean by 'ruler', my starting point was [any] grid that could be used to align successive images.
But, I have previously once or twice mentioned the possibility of adding vertical or horizontal 'guide lines', not an option I recall anyone supporting or requesting, which would actually have been a better solution for me than a grid.
When I started book scanning, I had the use of Photoshop CS2 and was able to position vertical and horizontal guidelines, which I used to align the margins of my page scans. That is something that might eventually be considered for 'MP (when it morphes from a very useful tool to an All-singing, all-dancing software), and could equally be useful for Draw if users understand them... :D
