I've downloaded the appimage, set the exec flag and tried to launch. The result is that nothing happens.
I have also tried the tar file but that would not run either.
I'm obviously missing something but I have other appimages that run as expected with no special tweaks.
Anyone have any suggestions?
Thank you
XnView MP 0.99.6 won't open on Fedora 35
DoctorDan
Re: XnView MP 0.99.6 won't open on Fedora 35
Don't know, I just found the app.
robbymilo
Also on Fedora 35 and appimages are not working. I've tried the latest version and versions all the way back to XnView_MP-0.93.glibc2.17-x86_64.AppImage. I get the error:
error while loading shared libraries: libnsl.so.1: cannot open shared object file: No such file or directory
robbymilo
With the tgz, I get:
symbol lookup error: /lib64/libk5crypto.so.3: undefined symbol: EVP_KDF_ctrl, version OPENSSL_1_1_1b-
AppImage 0.99.6 launches on Linux Mint 20.2 after editing the Properties to make the file executable.
@Pierre: Attached USB memories are also displayed immediately when opens, unlike the DEB version...
ewoks
Question was about Fedora, so please let's not hijack the thread.
Any update on fedora issues from XnView Team? Not even AppImage v0.99.7 can start at the moment..
/tmp/.mount_XnViewQebzwj/usr/XnView/XnView: error while loading shared libraries: libnsl.so.1: cannot open shared object fileCode: Select all
# dnf install libnslCode: Select all
symbol lookup error: /lib64/libkrb5.so.3: undefined symbol: k5_hashtab_free, version krb5support_0_MIT
