XnView crashing on startup
JeffK
Post by JeffK »
I just reinstalled the current version (64 bit) of XnView MP on my computer after not using it for many months. I am installing it on a Windows 11 laptop.
The program is crashing on startup. It appears to be while loading the initial "Pictures" folder.
Any advice would be appreciated.
Regards, Jeff
JeffK
Re: XnView crashing on startup
Post by JeffK »
OK hold your beers.
I've established that the program was failing upon accessing four .tiff files in my Pictures directory. These files, or at least one of them, may be corrupted in some way.
The files were created by photo editing using the Nik Collection. Whether that is an issue I will have to further investigate.
Thank you, Jeff
JeffK
Post by JeffK »
No further evidence that Nik is the problem. I can only think there was something odd about those four files. Neither putting them in a zip file nor renaming them away from the .tif extension resolved the issue. But deleting them altogether, XnView appears to be working fine.
could you send me them?
JeffK
Post by JeffK »
Hi Pierre, I have just sent you an email with the files attached. I'm not sure all the files were an issue but at least one was.
Jeff
right, thanks i'll fix it
JeffK
Post by JeffK »
Did you find it was an issue on your computer/s too? I thought it might have been just my setup. Corrupt file or clash with another running program.
JeffK wrote: Thu Dec 23, 2021 12:29 am Did you find it was an issue on your computer/s too? I thought it might have been just my setup. Corrupt file or clash with another running program.
yes it crashs always with these samples
JeffK
Post by JeffK »
Thank you Pierre. I have other .tif files created with the Nix collection which load without issue. So I don't know what is special about those files.
