Importing ACDSee keywords
LyndaT23
Post by LyndaT23 »
I have just changed from ACDSee to XNView MP. Is there a way to import the ACDSee keywords to XNView. They appear in XMP as Keywords but don't show in Categories.
Is there a way for them to show up in Categories?
thanks
Re: Importing ACDSee keywords
Do you have checked settings>Metadata>Import XMP subject?
LyndaT23
Post by LyndaT23 »
I have that checked in Settings.
I'm guessing that the ACDSee keywords aren't transferable to other programs so might need to redo all of these.
Post by michel038 »
If you can see keywords in Xmp tab (info pane in XnViewMP), I think you can recover them.
How are them shown ? "DC subject" ?
Did you use "Import folder" button (in Settings>Catalog)
Or View>Update catalog from files? (with a set of photos selected)
could you post an sample file, XnView can import ACDsee keywords
LyndaT23
Post by LyndaT23 »
In XMP there is an acdsee field. Terms that appear in categories show in XNViiew categories. acdsee keywords do not show in categories.
I have tried Import Settings > Catalog > Import folder, and also View > Update folder - neither seems to change what is shown in Categories.
Here is a screen shot of the info panel for 1 image
LyndaT23
Post by LyndaT23 »
Not sure if it came through on last message.
thanks
no could you send me a jpeg with xmp?
LyndaT23
Post by LyndaT23 »
Hope this is what you need
LyndaT23
Post by LyndaT23 »
Not sure if the last jpg I posted had XMP. Sorry for the mistake (not used to posting in forums)
this one has acdsee keywords in the XMP
thanks
in 'Category sets', when clicking on this file, i can see 'Europe' as assigned category
LyndaT23
Post by LyndaT23 »
Thanks for following up on this Pierre.
When you look at XMP data under acdsee there are listings for categories and keywords. The categories seem to have carried across but not the keywords. See attached screen dump of XMP for that file.
Can you shed any light on this? thanks again for trying to sort this out for me.
in 'category sets' do you see the imported category?
LyndaT23
Post by LyndaT23 »
No.
you have 'europe' so it's good
