I use only XMP sidecar to store file description, rating, etc, because I don't want to modify original files.
Actually, I copy (duplicate via Cut&Paste) the field XMP dc:description in file descript.ion and then I can search text inside descript.ion.
This is time-consuming (open, select, copy, close, open, paste, save, close) and provides the possibility of errors) in case of changes to the main text in XMP companion.
[Q] Is it possible to extend Quick Search (in top bar) to search text in XMP sidecar file?
Quick search in XMP companion
Re: Quick search in XMP companion
yes a good enhancement
cicciobello
My hero!
