Video files won't play in Full Screen viewer
stevemd
All my video files (.mov) play fine in Slideshow mode. And smaller video files (say 10MB) play in full screen viewer mode. However, larger video files (30 MB and 50MB) won't play in full screen viewer mode.
thanks
thanks
ckit
stevemd
I have
checked - Enable navigation with rgt and left mouse button
checked - Hide scrolbar
checked - hide play bar
auto image size - fit image to window, large only
unchecked - dual monitor stretch
check - dual monitor, use second monitor
check - use delayed high qual...
uncheck - show inform
If I uncheck everything - still doesn't play
The same videos play fine on version 1.80.3 (though the R-L mouse nav doesn't work on that version; mouse nav seems fixed on the beta version however)
the videos are .mov, 640x480 30fps
thanks
thanks
stevemd
Some additional info I just found on the non-playing videos...
If I switch from browser > viewer > fullscreen, the videos will play (using ENTER as switch mode option)
The failure is when I go from browser > fullscreen (via the double click setting to switch modes)
So it seems going thru the viewer works, but not going directly from browser to full screen.
Again, it all works fine on 1.80.3
ckit
Ok, I can confirm your bug with large MOV files when XnView's "Use double-click to switch between:" is set to "Browser <> Fullscreen | Viewer <> Fullscreen"
Also, make sure you have Apple QuickTime 7.0.3 installed.
Strange i have not changed video playing on beta 1. Do you have the problem with avi too?stevemd wrote:Some additional info I just found on the non-playing videos...
stevemd
stevemd
Someone with the same problem?stevemd wrote:Yes - it appears the exact same problem occurs with avi.
They play fine in 1.80.3,
In the beta, they play fine in the slideshow mode, and play fine if I go from browser > viewer>fullscreen, but they won't play going from browser>fullscreen.
Strange
stevemd
Pierre
I just tried beta 2 and the problem is fixed in beta 2! (I can still reproduce the problem in beta 1). In beta 2, 140MB avi and 30MB MOV files now play fine in preview and in browser>fullscreen.
FYI - i had the same default settings for max file size in version 1.80.3, beta1 and beta2 - I'm sure of this because I just copy the .ini file to the new folder for the new version
strange
Steve
strange
Steve
Cantonyz
help
I got this anime episode thats 223mbs and its in .mov format. When i open it with qt or qta it just plays the audio but i cant see ani thing. Can some one please help me fix this problem. plz reply to my email [email protected] and that is also my msn. Thank you very much
