then pathname contains "alex"
results, nothing to do with alex.
Search conditions don't work
obelisk
Re: Search conditions don't work
Could be that if you have more than 1 condition, it uses 'or' which is not very useful
Franky
"Use catalog" is valid ?
If you search in your catalog, you must have put your photos.
obelisk
Use catalog is off. Is it good to use?
Franky
"Case sensitive" is valid ?
You can make a screenshot ?
obelisk
no I mean it just lists EVERYTHING
might as well have 0 conditions
I used a few conditions and it'll just show anything that matches 1 thing
please make a screenshot, and which folder hierarchy do you have?
I've tried to reproduce your problem but without success. For me XnView's search (Tools > Search...) works as expected. At first, I forgot to check "Recurse subfolders" but after that one all jpg files in folders that matched the criteri were listed. Is option "Match all of the following conditions" set? A screenshot of your Search dialog would be very helpful, obelisk.
