0.99.7: "Open with" not working with Windows apps
Rick
Post by Rick »
XnView: MP 0.99.7 - 32 bit/64 bit
OS: Windows 10 64bit
Open with works well on files in Program files but with apps it fails i.e the alt+number doesn't work. I have a program in the following path:
C:\Program Files\WindowsApps\SerifEuropeLtd.AffinityPhoto2Beta_2.0.0.1343_x64__v5ap6qg21y3cg\App\Photo.exe
Effect: It doesn't work
1. Create an entry to a prog in windows apps
2. It will not load with the alt+number
Actual behaviour (bug): it doesn't load the program :bug:
Expected behaviour: It should load the progam
Rick
Re: 0.99.7: "Open With not working with windows Apps
it's not a right problem?
Rick
Post by Rick »
xnview wrote: Mon Mar 14, 2022 8:46 am it's not a right problem?
It is but the company involved is warning about taking control of anything in the windowsapp directory. I added myself to the security list and that worked around the issue (NO easy feat!!)
You still might want to address this as installs with the new MSIX format are installing there
Thanks
Rick
