See below for the email I sent to contact@
Just bought a macbook pro (used) and installed xnview after using xnview for several years on my macbook air (RIP).
When I go into fullscreen mode, and begin cycling/navigating through the pictures using the keyboard (have not tried mouse, prefer keyboard), the first two images display correctly (i have preload next image turned on; image resize set to Fit Image to Window under Preferences>View>Fullscreen), however when I go to the third image it only shows a small sliver of it at the top, the rest of the screen still remains as the previous image. Continuing to cycle through shows different slivers at the top (as it is cycling through the images and the image counter is correct ex. 14/123 <- shows the image it should be on but the image is obscured by the previous image that is not going away), and every once in a while, intermittently correctly shows one of the images, then that image becomes the "stuck" image obscuring any images after.
I've tried changing tons of settings, googling my brains out, emailing Pierre, and now I have found this support forum. Help!
**Email I sent prior to posting this**
I am using xnview for mac. I had used it for several years on my macbook air, it had a few bugs and issues but I was able to make do, and don't get me wrong, better than any other software available in the same space.
However, I had to replace that, and purchased a macbook pro. Just installed xnview on the pro, and the way I normally view photos is I go to the folder, double click the first image, then click the icon for fullscreen. Then use the keyboard for navigation/zooming/etc
However, on this new install I just did, when I try to do that, it works fine, shows the first image in full screen. Then I click the right arrow and it correctly shows the next image (i have "preload next image" turned on). However, no matter what I have tried, nothing changes the fact that when you hit the right arrow for a second time to go to the third image, the current (2nd) image does not disappear and at the top, maybe about an inch or less of the next (3rd) picture shows up on top of the incorrect image.
If I keep going pushing the right arrow, you can see its cycling through the images (and the counter shows the correct image number in the info area, and if i hit enter to exit fullscreen, then hit enter again, it will be on the correct photo
Also, maybe 5% of the photos will show the whole image, then that photo becomes the one that is "stuck" and covering the other images as I cycle through.
I have googled until blue in the face on this. I cannot even find anyone with this same issue! I have changed just about every preference that seemed relevant as well, and disable as much as I could that was disable-able.
Also, not sure how/if this matters, but intermitently the preferences (and about XNview) will be "grayed out" in the XNview menu (the far left menu next to the apple), and I have to quit and restart XNview to get them to be available again.
Help! Please!
XnView MP MacOSX
Version 0.99.7 64bits (Jan 13 2022)
Libformat version 7.100
Email: [email protected] - [email protected]
URL: http://www.xnview.com - http://www.xnview.org
Toolbar icons from mezich (no use without authorization)
Logo & app icon from thibaud
File-type icons from budz45
System Report:
Hardware Overview:
Model Name: MacBook Pro
Model Identifier: MacBookPro8,1
Processor Name: Intel Core i5
Processor Speed: 2.4 GHz
Number of Processors: 1
Total Number of Cores: 2
L2 Cache (per Core): 256 KB
L3 Cache: 3 MB
Memory: 16 GB
Boot ROM Version: 87.0.0.0.0
SMC Version (system): 1.68f99
Serial Number (system): C02H6UXNDV13
Hardware UUID: 564F8AEA-8766-5AC8-9AE6-8B964B1CAFFC
Sudden Motion Sensor:
State: Enabled
Intel HD Graphics 3000:
Chipset Model: Intel HD Graphics 3000
Type: GPU
Bus: Built-In
VRAM (Dynamic, Max): 512 MB
Vendor: Intel
Device ID: 0x0126
Revision ID: 0x0009
Displays:
Color LCD:
Display Type: LCD
Resolution: 1280 x 800
UI Looks like: 1280 x 800
Framebuffer Depth: 24-Bit Color (ARGB8888)
Main Display: Yes
Mirror: Off
Online: Yes
Rotation: Supported
Automatically Adjust Brightness: No
(hard drive)...
Untitled:
Available: 37.74 GB (37,741,158,400 bytes)
Capacity: 127.83 GB (127,825,920,000 bytes)
Mount Point: /
File System: APFS
Writable: Yes
Ignore Ownership: No
BSD Name: disk1s1
Volume UUID: F09E37A7-1967-36AF-BA47-AD1FCED9177D
Physical Drive:
Device Name: SanDisk SD6SB1M-128G-1006
Media Name: AppleAPFSMedia
Medium Type: SSD
Protocol: SATA
Internal: Yes
Partition Map Type: Unknown
S.M.A.R.T. Status: Verified
Intel 6 Series Chipset:
Vendor: Intel
Product: 6 Series Chipset
Link Speed: 6 Gigabit
Negotiated Link Speed: 6 Gigabit
Physical Interconnect: SATA
Description: AHCI Version 1.30 Supported
SanDisk SD6SB1M-128G-1006:
Capacity: 128.04 GB (128,035,676,160 bytes)
Model: SanDisk SD6SB1M-128G-1006
Revision: X231706
Serial Number: 141703400054
Native Command Queuing: Yes
Queue Depth: 32
Removable Media: No
Detachable Drive: No
BSD Name: disk0
Medium Type: Solid State
TRIM Support: No
Partition Map Type: GPT (GUID Partition Table)
S.M.A.R.T. status: Verified
Volumes:
EFI:
Capacity: 209.7 MB (209,715,200 bytes)
File System: MS-DOS FAT32
BSD Name: disk0s1
Content: EFI
Volume UUID: 85D67001-D93E-3687-A1C2-79D677F0C2E0
disk0s2:
BSD Name: disk0s2
Content: Apple_APFS
XnViewMP:
Version: 0.99.7
Obtained from: Identified Developer
Last Modified: 1/13/22, 3:03 AM
Kind: Intel
64-Bit (Intel): Yes
Signed by: Developer ID Application: pierre gougelet (ULQ448ZAS2), Developer ID Certification Authority, Apple Root CA
Get Info String: XnViewMP © Copyright 2007-2022 Gougelet Pierre-e
Fullscreen Mode only displays first two images correctly when navigating in fullscreen
cryptothick
Rick
Re: Fullscreen Mode only displays first two images correctly when navigating in fullscreen
I get that in the Windows version; one thumbnail is on all as you scroll
Click one of those thumbnails and they will all appear on that screen. I think it is a refresh issue
Rick
Rick
could you try the 1.0 beta 2? I have no more high sierra to try
