Difficulty downloading XnView MP for Mac 10
Weinee3947
Post by Weinee3947 »
Cannot download xnviewer mp because of identification of developer can’t be found.or the file is damage or been tampered with.I went to xn ‘s web site to download it and still doesn’t work any ideas on it. using Mac 10 .?
Re: Difficulty downloading XnView MP for Mac 10
Which MacOS version do you have?
Weinee3947
Version is 10.13.6
strange, in settings>Privacy, you can authorize the app
Weinee3947
Ok guys I got the app working it still shows cannot verify it,but it has click to open which it opens it up what I’m doing is trying convert sfw files to jpeg I go to files select all files then to tools and seclect batch files than to the one below source bottom click the bottom one .than to file name click jpeg guartor or any the other ones and click convert . After converting finished I have error message did this several times so what doing wrong here .
which error message?
Weinee3947
Hi one last try I can view the pictures without problems, still cannot convert sfw files to jpeg all it says is error and nothing else ,other times it want permissions for what I don’t know. The last time I use this viewer it was on a pc without any problems. Is there a possibility getting instructions on how to convert files. maybe step by step possibly I don’t know thanks
Good to read that you could start XnView MP on your Mac.
There at least two ways to convert an image:
a.) Open image in XnView (image view mode) and then use "File > Save as.." and choose a file format.
b.) Batch conversion (In XnView browser select one or multiple files and then choose "Tools > Batch convert...". In panel "Format" you choose the desired format.
Could you please describe your steps to convert your sfw file? What is the exact text of the error message?
Weinee3947
Hi I got it to convert one picture at time to jpeg ,but to do a batch convert . Go to tools and to batch convert it goes this panel it has input ,actions output status . then I click big thumbnail all pictures all pictures come up Below it it has add files -add folders which takes my files and loads them.I went to to output in it it has source folder - folder to right typed in the disk no. Did not type anything in file name went to format and clicked jpg-jpeg/ jfif then click convert couldn’t find a destination drop down box on where to put it. also the panels is in view tab and is grayed out have no clue where they went .
Thank you for your reply, Weinee3947.
From what I can read in your description, output folder and filename is not specified. Please try out the step-by-step description in How to batch convert and batch process with XnView MP. I cross my fingers that you succeed.
Weinee3947
Ok guys I did what you said I click convert they loaded and had create error I went to output changed webp to jpeg/jfif and same as original andi went back to misc folder , but it couldn’t open it .guys I never had this kind of a problem before ,I usually can find the problem and work it out .this one is a nightmare I just want thank you guys for having patience in helping me. I have spent hrs on this app trying figure it out ,but not going give up just yet . I know there got to be a way to get to work i think thanks
Thank you for another trial and reply, Weinee3947. "Nightmare" doesn't sound to good. :( Your description is a bit hard to follow and a detailed error message is missing. Could you perhaps take screenshots of the tab "Input", "Action" and "Output" of batch conversion plus the error message? A screen video would be even better. With that extra information we might find the reason of your current problem. ATM, this sounds much like a problem of "Access rights" to me.
