1. Same 32bit image saved as HDR format looks dark versus EXR format.
When both files open in Photoshop they look identical.
Files https://www.upload.ee/files/14040027/Ph ... 1.zip.html
P.S. Is there way to assign "ProPhoto RGB" color profile to 32Bit images only for HDR and EXR files?
*.HDR too dark.
FKCapitalism
*.HDR too dark.
Re: *.HDR too dark.
do you have changed the gamma in settings>Formats>Read?
FKCapitalism
Re: *.HDR too dark.
No, tested also with version 1.0 beta 1, no settings changed.
Re: *.HDR too dark.
you need to check settings>Formats>Read
FKCapitalism
Re: *.HDR too dark.
Adding gamma in HDR settings does fix it somewhat, but not entirely.
1. Thumbnail still looks dark its not affected by gamma settings (i did use "rebuild thumbnails")
2. Image looks overexposed in the bright areas e.g. sky.
