Multiple icons
Stormu
Multiple icons
Post by Stormu »
Hi!
First I want to say this is a great software, lightweight and fast.
Question is:
Is there any way -NOT- to get the "Multiple icons" pop up when navigating in viewer ?
Its so annoying.
Thanks!
Re: Multiple icons
Welcome to the forum, Stormu (-:
  1. Go to Tools → Options → File List → File List and untick the checkbox for All other files / Show item in view Other.
  2. In browse mode, go to View → Filter by and make sure that Custom is selected.
This will prevent the icons embedded in *.EXE, *.DLL files etc. from being loaded by the viewer.
Related: How to turn the "Multiple icons" off?
Stormu
Re: Multiple icons
Post by Stormu »
Thanks mate!
I really appreciate the help.
Cheers.
