b2: Additonal separator in context menu
Locked
A minor change which will improve usability quite a bit, so I repeat it (original topic):
"In the context menus for preview, view mode, and fullscreen mode, the menu items for Zooming should be separated from the menu items for navigation using a separator. This will make the context menu clearer."
FlorianH
Re: b2: Additonal separator in context menu
Post by FlorianH »
helmut wrote:"In the context menus for preview, view mode, and fullscreen mode, the menu items for Zooming should be separated from the menu items for navigation using a separator. This will make the context menu clearer."
There is a separator in context menu of the preview pane. I think separators in the other menus as described by Helmut would be good...
helmut wrote:A minor change which will improve usability quite a bit, so I repeat it (original topic):
Ok, only in fullscreen mode
Verified fixed in Beta 3.
Locked
