XnView w/High Sierra on a Mac
zintc
I've been using XnViewMP without problems until I upgraded to your latest version. I'm on a Mac running High Sierra, 10.13.6, and get the spinning color wheel almost right away. I've reinstalled several times, but no luck. I've also tried an older version, 98.3, without success.
Please help!
Please help!
Re: XnView w/High Sierra on a Mac
the app doesn't startup?
zintc
Thanks Pierre!
It starts and I can see folders and pictures, but I quickly get the spinning color wheel and have to force quit.
Thank you!
Thank you!
In this folder, which format do you have?zintc wrote: Sun May 22, 2022 1:43 pm It starts and I can see folders and pictures, but I quickly get the spinning color wheel and have to force quit.
zintc
In the folder are psd's, afphoto's, dng's, and NEF's
are you able to change the folder? Perhaps a file locks XnView
zintc
I emptied the folder using the finder where the potential file might be. Then, I shutdown the computer and restarted. Interesting, when I launched XnViewMP (latest version), it displayed the files that used to be in the folder, then I got the spinning color wheel and the only way to quit was to force quit. How else could I remove the files from the folder? The spinning color wheel shows up almost immediately.
Thank you for your help!
you have in XnView MP the files that you have removed with Finder???zintc wrote: Mon May 23, 2022 2:22 pm I emptied the folder using the finder where the potential file might be. Then, I shutdown the computer and restarted. Interesting, when I launched XnViewMP (latest version), it displayed the files that used to be in the folder, then I got the spinning color wheel and the only way to quit was to force quit. How else could I remove the files from the folder? The spinning color wheel shows up almost immediately.
there is something false here, XnView show contents of folder like Finder, you have not rights problem in this folder?
zintc
No, I'm able to view the contents of the new folder and the old folder with the Finder. But in XnView MP, the application doesn't see the new folder and all the images are in the old folder. The spinning wheel shows up quickly and I have to force quit.
'Filter by' is on all?
zintc
I don't think I changed this setting. The application crashes before I can find out. Other than by star rating, I don't usually filter my photos. I organize by folders.
could you try to rename xnview.ini?
zintc
My understanding is that .ini files are Windows files. True? I'm on a mac, not Windows.
