Scrollbars too narrow on Win 10 + fix
jan_m
Post by jan_m »
XnView MP 1.0 64bit
Windows 10 Home 21H2 64-bit
2 monitors:
- Main (no display scaling): 1920x1200
- Secondary (display scaling: 200%): 3840x2160
On a default, clean installation of XnView MP on Windows 10, the scrollbars are too narrow. I think this is a HiDPI bug.
Example screens:
If I open an image, close the Browser tab, then re-open the Browser tab, the scrollbars are the correct width.
Luckily, this is easily fixed by changing the HiDPI setting to "System"
Hope this helps and thank you for creating XnView!
Re: Scrollbars too narrow on Win 10 + fix
Thank you, jan_m, for registering here and reporting your problem including solution. :)
