Shortcut to iptc/xmp templates
Gerald_Ire
Post by Gerald_Ire »
Hi Pierre, thx for comming back on this.
We like todo xmp-templates. And the content-template has to be applied manualy for each image.
I can type content into XMP-fwc and can save it as a sample as *.xxmp
The templates including content for a few metadata fields. Sound good so far...
I can share the *.xxmp-files with all users via AppData\XnViewMP...
The user can view all of the *.xxmp in the list but it doesnt apply on the image any how. Maybe this is my wrong thinking.
What I found instead is a seperate "history list" for each single xmp-fwc customfield. Not easy to access for some fields. Maybe there is an option missing (see next image)
Option to open this list found in an other metadata field... (next image)
The list for each field...
The applied content can access to each image and its shown under each single xmp-fwc customfield
Just figured out: all content gets saved in the XMP.ini - thats brilliant!
What I do not get is a template for more than one metadata field as I can do with the *.xxmp
Question: where is my wrong thinking or doing? How can we apply the content to an image manualy with the *.xxmp-templates?
:D Gerald says thx to all! :D
Re: Shortcut to iptc/xmp templates
Gerald_Ire wrote: Wed May 04, 2022 2:03 pm The user can view all of the *.xxmp in the list but it doesnt apply on the image any how. Maybe this is my wrong thinking.
you can't apply a saved .xxmp? nothing happened when you select it?
Gerald_Ire
Hi Pierre, sorry for the delayed answer...
The answer is no. If I/we apply a XMP-template it wont write the Metadata into fwc xmp fields.
(by the way this is ver. 1.00)
The original file with "ModifyDate" befor...
Open it into XMP, choosed one of the *.xxmp templates (sample attached *.zip)
Applied it to fwc 1-3, but it doesnt show up in GUI...
And doestn show up in Metadata XMP, but ad CreateDate to it... (ModifyDate?)
If I edit it manual (typing text), it shows up...
Will try this later on my private Windows PC to check if its a "rights thing" on AppData/... and let you know tomorrow... 25th...
The *.xxmp is enclosed from ...User/AppData/XnViewMP...
Gerald_Ire
Sorry for the delay!
Checked *.xxmp templates on my priv. pc (win10) with version 1.00...
Did that with "standard setup" (... like install, ok, ok, ok, done!)
Same problem: Cant apply the templates to xmp metadata...
Post by michel038 »
Right.
XMP templates are not working in "Edit xmp" dialog.
The fields stay empty
This problem could be mentioned in the bug reports section of the forum
When the bug is solved, we can continue here to discuss the possibility to apply templates in one click
Templates are working in "Edit iptc" dialog, with IPTC metadata
(... and if mode "IPTC + create or update xmp" is enabled, xmp fields will also be updated.)
Gerald_Ire
Merci bien! Thx for reply to this. Didnt checked the IPTC version on this...
... and: bug report to this is now done! Thx to all!
Gerald_Ire wrote: Tue Jun 07, 2022 11:20 am Sorry for the delay!
i can't reply to your email (it returns as spamming :( )
As a workraround, in the xxmp, please try to remove the lines <Iptc4xmpCore.CreatorContactInfo.... at the beginning
Gerald_Ire
Workaround does the job. Thx for quick reply!
See sample with deleted lines:
<?xml version="1.0" encoding="UTF-8"?><!DOCTYPE xmp_template><xmp_template version="1.0">
<Iptc4xmpCore.CreatorContactInfo/Iptc4xmpCore.CiAdrCity></Iptc4xmpCore.CreatorContactInfo/Iptc4xmpCore.CiAdrCity>
<Iptc4xmpCore.CreatorContactInfo/Iptc4xmpCore.CiAdrCtry></Iptc4xmpCore.CreatorContactInfo/Iptc4xmpCore.CiAdrCtry>
<Iptc4xmpCore.CreatorContactInfo/Iptc4xmpCore.CiAdrExtadr></Iptc4xmpCore.CreatorContactInfo/Iptc4xmpCore.CiAdrExtadr>
<Iptc4xmpCore.CreatorContactInfo/Iptc4xmpCore.CiAdrPcode></Iptc4xmpCore.CreatorContactInfo/Iptc4xmpCore.CiAdrPcode>
<Iptc4xmpCore.CreatorContactInfo/Iptc4xmpCore.CiAdrRegion></Iptc4xmpCore.CreatorContactInfo/Iptc4xmpCore.CiAdrRegion>
<Iptc4xmpCore.CreatorContactInfo/Iptc4xmpCore.CiEmailWork></Iptc4xmpCore.CreatorContactInfo/Iptc4xmpCore.CiEmailWork>
<Iptc4xmpCore.CreatorContactInfo/Iptc4xmpCore.CiTelWork></Iptc4xmpCore.CreatorContactInfo/Iptc4xmpCore.CiTelWork>
<Iptc4xmpCore.CreatorContactInfo/Iptc4xmpCore.CiUrlWork></Iptc4xmpCore.CreatorContactInfo/Iptc4xmpCore.CiUrlWork>
<Iptc4xmpExt.Event></Iptc4xmpExt.Event>
<Iptc4xmpExt.OrganisationInImageCode></Iptc4xmpExt.OrganisationInImageCode>
<Iptc4xmpExt.OrganisationInImageName></Iptc4xmpExt.OrganisationInImageName>
<Iptc4xmpExt.PersonInImage></Iptc4xmpExt.PersonInImage>
<dc.creator>Gerald</dc.creator>
<dc.description>Test</dc.description>
<dc.rights></dc.rights>
<dc.title></dc.title>
<fwc.CustomField1>1</fwc.CustomField1>
<fwc.CustomField10>10</fwc.CustomField10>
<fwc.CustomField2>2</fwc.CustomField2>
<fwc.CustomField3>3</fwc.CustomField3>
<fwc.CustomField4></fwc.CustomField4>
<fwc.CustomField5></fwc.CustomField5>
<fwc.CustomField6></fwc.CustomField6>
Sorry for the SPAM problem. Using new mail software & mail server. Will talk to admin...
you have another bug?
Gerald_Ire
Oh Sorry! Nope!
Just deleted the other post!
This problem is supposed to be fixed in XnView MP 1.01. Please check and confirm the bug fix here.
Gerald_Ire
Yes! +1*
Sorry for the delay! :-(
Create and Save template...
Load and Apply template
Check XMP - metadata
