XnView MP displays jpeg very fast but slow with Fuji RAF.
Am I doing something wrong?
Display slow with Fuji RAF [Solved]
mapline
Re: XNView mp display slow with RAF ?
Loading RAW can be slow, you can use 'Settings>View - Camera RAW -> embedded jpeg'
mapline
Re: Display slow with Fuji RAF?
Thank you Pierre for the reply.
However in Settings it only gives Camera raw use embedded preview and that doesn't work as it is just as slow?
mapline
All OK found found the setting in Browser>Thumbnail>Use embedded thumbnail and that worked.
