Copying or printing search results
mstratil
Post by mstratil »
I have learned how to search for files containing specific exif information. But I cannot figure out how to copy or print the results. My search found 800 files matching my criteria, and I need this list of file names.
Can someone help me figure out how to do this?
Mike Stratil
Re: Copying or printing search results
Post by michel038 »
Hello
You can use : Create > File listing menu
If you want to reopen in xnviewmp your list with the "File > Open list" menu, you have to respect a particular formatting:
- Use "Text" format when creating the list, and ...
- either use only {Directory}{Filename With Ext} in the first box
- Or, use double quotes "{Directory}{Filename With Ext}" in the first box , and any other data in the same box, or in follwing boxes
- Edit your file and remove the first line, containing headers
Other info
If there is one field by box, the separator of fields will be a "Tab" character
You can also add many values in the same box, so you can choose your separator character such as
"{Directory}{Filename With Ext}";{Size};{Format};{Comment} with semicolon
mstratil
Post by mstratil »
Hi Michel,
Thank you for your suggestion. But I'm not sure I understand.
My problem is that I can't figure out how to select all the lines in the results window. I can create a file, but it has no content. Can you instruct me on how to select all of the results in the results window?
Best regards,
Mike
Post by michel038 »
Sorry, I forgot the beginning
The search function gives a window with n files found .
Click on the "Browse" button to display these files in the browser, then select all of them (Ctrl A)
... now you can follow the instructions in my first post and use "create file list"
Depending on your needs, I can advise you on the settings to use
I think you should first try on a small folder to set up the method
