Removing transparency
obelisk
Post by obelisk »
I wondered if there was a way to batch convert and output tiff but transparency -> white, like how it does for jpg?
Re: Removing transparency
do you have a sample file?
obelisk
Post by obelisk »
  1. Open transparent.gif in the viewer.
  2. Go to Image → Change color depth…
  3. Select 24 bits and a background color.
FYI: transparent.gif is in fact a PNG image with a wrong file type extension.
obelisk
Post by obelisk »
Thank you this worked well.
