- (Good) XnView is open on Monitor 0; I close it and the "Save changed file" warning appears in the middle of the window.
- (Bad) XnView is open at the bottom of Monitor 1; I close it and the "Save changed file" warning appears on a different monitor.
- (Very bad) XnView is open at the top of Monitor 1; I close it and the "Save changed file" warning is not visible.
Close button is invisible with certain dual monitor setups
Poobslag
I have two monitors with different dimensions, Monitor 1 is much taller than Monitor 0. When I close XnView in Windows, a "Save changed file" warning appears on Monitor 0 regardless of which monitor XNView is open on, resulting in a few different cases:
