XnView: MP 1.01 - 64-bit
OS: MacOS
Can't open/view any AVIF file.
Also, file Browser hangs when selecting avif file (on Exif tab active)
MacOS 1.01: No support for AVIF on MacOS
Re: MP 1.01: No support for AVIF on MacOS
currently avif is only supported on Windows x64
magick
Any chance to add support for MacOS in the near future?
BTW, There are some apps/libs that work with it on MacOS already
eg.
AVIFQuickLook https://github.com/dreampiggy/AVIFQuickLook
Libavif https://github.com/AOMediaCodec/libavif
LibAOM https://aomedia.googlesource.com/aom
First two can be easily installed by brew (https://formulae.brew.sh/formula/libavif#default)
Lastly, it seems the newest macOS will support it since Ventura beta properly shows AVIF in the Finder and the built-in Preview application.
eg.
