Metadata not saved
t4g
Metadata not saved
Post by t4g »
Previous settings saved metadata - eg pic rating.
New version, settings not working.
Metadata not saved.
Ver1.2 64bit XnV MP
Windows 10
Thank you for your work and for fixing this bug.
Stay safe.
Re: Metadata not saved
Post by michel038 »
You want to add a star rating to a jpg picture ? or another type ?
Tools>Setting>Metadata>Export rating to xmp is enabled ?
Then, you select the picture (browser mode or view mode ?), set rating, and deselect picture...
When you select this picture again in the browser, in Information area, XMP Tab, there is no rating ?
t4g
Post by t4g »
Precisely..
Post by michel038 »
Did you try on other pictures, in other folders ?
Do you have a good knowledge of Windows? ( locked files ? special characters in paths ? difficulties with network drives ?)
Did you enable xmp companion files ?
What about other metadata ? (Tools,Metadata, Edit xmp... )
You can perhaps try a new xnview.ini file...
(Stop xnviewmp, move the current one, Xnviewmp will create a new xnview.ini) set again export option etc...
If it's not better, put the old one back in place.
I tried on a new installation, metadata are ok for me...
t4g
Post by t4g »
Hi Michel
Thank you for your email.
If it works for you it must (eventually) work for me.
I'll try/ test all the things you suggest and come back..
8)
t4g
Post by t4g »
OK Michel
Think I have worked it out.
Metadata saved with .jpg.
Metadata not saved with .webp.
Is there any way to get metadata saved with webp images, please?
Thank you.
TrailQuest
Post by TrailQuest »
Recently noticed Adobe .DNG files were not being updated with XnView MP\Metadata\Edit XMP. Found that 'Tools\Settings\Metadata\Sidecar\Create or update XMP Sidecar' was not checked. Checked and seems to work now.
t4g wrote: Thu Sep 01, 2022 12:06 pm Metadata saved with .jpg.
as emebedded?
Post by michel038 »
Embedded, yes for me, it was my request there
viewtopic.php?f=101&t=47757
