Cheers
Opening multiple images from file viewer
Wain
In the file viewer, if I select multiple image files and then shift-double click on them it only opens the last image selected and not all of them. The expected behaviour would be to open all of them (in tabs), which is how it worked in XNView Classic and is consistent with how the Windows and Mac UIs work.
Cheers
Cheers
Re: Opening multiple images from file viewer
you can press CTRL
Wain
Thanks! I'll try ctrl.
It's still unexpected behaviour. Windows and Mac UI don't work that way, nor did XNView Classic. Is there any way to know that ctrl double click works? It seems like a hidden function.
