Alpha in thumbnails
Wain
Alpha in thumbnails
Post by Wain »
The file browser shows alpha in preview thumbnails even if you've turned off "Use Alpha Channel" and then rebuilt the thumbnails. At least, this is the case with png and blp images. It means that some preview thumbnails are almost invisible when they have strong alpha masks.
In XNView Classic, you could open an image, turn off "Use Alpha Channel", then return to the file browser window and rebilld thumbnails, and it would render them without alpha channels.
Re: Alpha in thumbnails
you don't want alpha in thumbnail?
Wain
Post by Wain »
Not if I've selected the menu option for it to not display, no. For many images I'm working with, it's hard to see anything in the thumb if alpha is active.
XNView Classic worked that way.
please try to change in your xnview.ini
useAlpha=false
in Load section
MARK2580
Post by MARK2580 »
xnview wrote: Mon Sep 12, 2022 12:34 pm please try to change in your xnview.ini
useAlpha=false
in Load section
Is there some kind of command/button to enable/disable this option on the fly? For example, I have a bunch of textures with transparency and their previews are displayed 90% as just a black square. But I don’t always need to disable this feature.
